U can go up 2" with a staight block or get a rox or powermadd pivot adapter with a 2"block...total 3.5" But since you are using a straight bar you need to measure how much of a rise you get out of a stock bar and then you can add that to your total riser block you use.
Yes I had just a two inch block and just recently went with a powermadd pivot adapter and a 2" block with no cable mods. Just make sure U have no binding after you set it up.
