Handlebar hooks on a Vector?
mbw919
Charlevoix, Michigan
If I were to add handlebar hooks to my '06 Vector GT, can I retain the stock grips? I wonder how much of the grip end would need to be removed and if that would cut into the heating elements. I nearly fell off the other day when my left hand slipped off the end of the grip after landing a little crossed up from hitting a snow bank. It doesn't help that my left radius and ulna are held together with two 6" plates and a dozen screws and I'm getting arthritis in my fingers. :o|
:rocks:
Be really carefull when you cut into the end of the grip and you should be fine. I just used a skill knife with a really sharp blade, took my time and voila... others may have an easier/cleaner method, but the 'jaged' edges left by the rasor blade were covered entirely by the hook.
Falling off SUCKS! ;):D
Here are some pics of mine.
you only need to cut or drill a small hole in end of grip.just big enough for hook shaft to slide into.no need to cut end of grip vertical way.
if you need hooks i have some brand new in black 45 degree angle for $10 each .they are plastic and wopnt take away heat from hand grips.
I'm interested. Let me know how you prefer to procede.
got it and boxed.you will see it on fri. via priority mail.thanks
