Johny P
- Jan 30, 2007
- Stephenville, Newfoundland, Canada
I have a 2007 Attak with the following Mods:
- Ram Air Intake
- Power Commander III
- Hauck Exhaust
- Ulmer Stage 2 Clutch Kit.
I'm having a little trouble with this new setup. The sled is hard starting now, and floods easily. I've already killed two sets of plugs. IF, I can get it started, she dies out, and the I can't get it to start until I change out the Plugs....and we all know what a Pain in the A@# that is
ANY SUGGESTONS!!! I'm runiing the stock NGK Plugs. Should I be running a different Plug? - Hotter?, Different Gap?
Thanks,
Johny P
- Ram Air Intake
- Hauck Exhaust
Thanks,
Johny P
LJ 452
Without knowing who you got the Power Commander from I would guess that either that's your issue or something unrelated, like a TPS or something else. If you got the P.C. from Ulmer I would try to put it back the preset or contact him. Is it difficult to remove the P.C. from the system, not permanently just to test? That way you could eliminate the possibilities one by one. I don’t have any experience with the P.C.’s so excuse my ignorance to them.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Johny P,
I agree with LJ, I would try temporarily disconnecting the Power Commander to see if that helps. If it does, you will then have to contact whoever sold it to you for help troubleshooting/programming it.
Welcome to TY! Please add your location to your profile.
PCIII is very easy to unplug for a quick test.
