schroon
- Mar 8, 2006
- Schroon lake, NY
- www.pacific-custom.com
Why is it after my 06 Vector sits for 3-6 weeks it will not start? I have to pull the airbox, cover each carb with my hand, and also prime it. Then it fires. If I just choke it and turn it over after it sits, all it does is just wear the battery down, doesn't even fire.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
schroon said:Why is it after my 06 Vector sits for 3-6 weeks it will not start? I have to pull the airbox, cover each carb with my hand, and also prime it. Then it fires. If I just choke it and turn it over after it sits, all it does is just wear the battery down, doesn't even fire.
You sure it is not sitting longer?
I can see 6 weeks maybe causing an issue but 3 weeks shouldn't imo?
Anyways, the gas tank/system needs to be pressurized.
Lots of info in these sections, just have a look as Sab1 just went through this so his post shouldn't be too hard to find.
Good luck.
found it right below your post.
http://www.ty4stroke.com/viewtopic.php?t=105069
Have you ever changed the plugs in this machine? Fresh gas,strong battery and new plugs is where I would start.
swmichvector
- Jan 27, 2009
- Clare, Michigan
- 2011 NYTRO
its normal, i usually lift the airbox lid and just give each carb a very slight mist of starting fluid and it starts right up. just a very very slight mist of starting fluid!!!! i have not had any luck with the other tricks.
swmichvector
- Jan 27, 2009
- Clare, Michigan
- 2011 NYTRO
ahamay said:Have you ever changed the plugs in this machine? Fresh gas,strong battery and new plugs is where I would start.[/quoteif you change the plugs i recommend the iridium plugs. put them in mine and it seemd to start easier and run a little smoother.
yank
- Jan 3, 2006
- Cook,MN
- 2005 rs venture
2006 rs rage
1971 elan
A dealer mechanic told me the carb bowls dry out fast in some of these sleds due to residual engine heat and over-sized carb vent tubes. I necked my vent tubes down to 1/8" to slow down the evaporation in the bowls. if my sled sits more than a month, I just pull off a gas line next to the fuel pump & manually fill the bowls w/ a small funnel. Pops off every time after that.
- 7K
