yammi4ever
I must be getting weak, seems my attak is steering harder than I remember. Everything is lubed like it should be. What is my best way to relieve some ski pressure. Took off the doolies and it helped some, but seems like I should be able to lighten it up more.
Thanks,
kirk
Thanks,
kirk
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Lengthen the limiter strap should take some pressure off the skis...........play around with front shock springs too........but keep in mind if your an aggressive rider you'll probaly want to keep that limiter right where it is since lenghtening it will reduce ski pressure and cause more inside ski lift cornering hard.
RX1-er-2005
Jack your front end so your skiis are off the ground and see how free everything is, I had and many others problems with the bushing behind the chaincse, it seems to dry up and get EXTREMLY tight and SQUEAKY on some RX1/Vectors and APEX/ATTAK body styles (4strokes)
If thats the case take it apart and LUBE it with a good quality grease I "ZERTED" mine, also check and lube the 2 steering column BUSHINGS they tend to seize up to...
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
lengthening the limiter can also cause ratcheting for some....and faster slide wear..
