Has anyone put Fox Float X shocks on an Apex?
mikeyZ06
Erie, PA
Or do you know if it can be done? If you've done it do you like'em?
Thanks!
Mike
Friend of mine had them installed on his attak. no problems.
Does Fox produce the Float X in the shorter size required for the stock arms? I run the 18.75" X that Fox built for the Arctic Cat Sno Pro. Long arms are required to run these, along with the proper bushing adapters. The ride is simply awesome.
I am considering upgrading to the Evol. If you decide to go long arms with 18.75" X shocks I can give you a deal on mine.
