Hauck Exhaust install pics
Churchill Falls ,NL
Canada
2015 Viper MTX
Does anyone have a pic of their Hauck exhaust installed without the covers/plastic installed on their Rx sleds???..I have a new Hauck exhaust bought and I would like to see exactly where you rivet the little "L" brackets that came with the kit for the heat shield
cheers
I just install them after the pipe is in and the shield is set in place. You drill out the rviets to get it off and notch the cover to clear the pipe set it in place and drill and rivet the piece on.
I have installed over 8 of them this way.
install
Just finished the install last nite..hopefully will get the sled running this weekend..work is sorta getting in the way..pretty easy install,I was just checking for pics of where the "L" brackets were rivetted..
cheers
Oh sorry that work thing does suck. I was supposed to leave Sunday for the UP for 4 days of set up and now I have a large project to supervise till Wed. :o|
Anyhoo the brakets just go on the heat shroud on the rear location is not important just set in place and then locate the brakets and drill and rivet to the shroud first.
BE EXTREMELY CAREFUL WHEN DRILLING INTO THE TUNNEL your coolant line runs through there and I have seen guys drill right through it "son of a #$%&* "
Oh you smart cookie - he who remove coolant line live to ride long time :-o
pics
Install complete..man that hauck exhaust sounds awesome..can't wait to get her out and make it scream...
