LazyBastard
Cubby's RX-1 said:LazyBastard said:Hmm.. exhaust makes no gains unless you're doing something weird that requires way more exhaust flow.
CDI - if retarding the ignition by 4 degrees makes it go faster, then just retard the ignition.
CDI - NO REV LIMITER. Cheap SOB's.
Yo please define "wierd" when using this exhaust and no rev limiter??? I am not a expert but wouldnt a lake run at full throttle be a little damaging to an engine without a rev limiter?????Cubby
Weird means turbo, ram air modification, NOx, thinner head gasket, etc.
Running a lake at wide without a rev limiter would DEFINITELY be dangerous - if your belt blows then so does your motor!
Cubby's RX-1
- Nov 14, 2003
- Willoughby, Ohio
- www.cubbyscustoms.com
LazyBastard said:Cubby's RX-1 said:LazyBastard said:Hmm.. exhaust makes no gains unless you're doing something weird that requires way more exhaust flow.
Thanks there LB, for the reply. And I understand "wierd" now. So maybe with Freddies Stage II the exhaust I have now will show some HPs because (heheheh) it would have nothing to do with what Freddie did.
Wow, My new louder exhaust just started gaining a couple of HPs as the manufacturer said it would!!! Woo Woo.............Cubby
