Grunter
- Jan 24, 2006
- Northern Ontario
- ZR9000
Has anyone installed Hauck's GHT R DUN yet?
Does it pull as hard or harder than stock if so what about top end? I'm not fully done exploiting this baby yet! Initially with stock clutching - it does not pull and you loose bottom end!
I've raised the engagement to 4200-4400rpm from 3500rpm and I've finally matched the torque I had before! (I've got the filters & timing key in there - and with a stock exhaust - it was a beast!) Now I'm working on the top part and at 10200-10300 so far with mixed feelings! I think it's coming along! I'm setting up to run at 10400-10600 like instructed - hopefully it's worth the dime then!
Any feedback/suggestions from anyone is most welcome!
P.S. - Hauck wants to sell the clutch kit with it - but I've always evaluated a pipe on it's own merit first! I do not want to blend in or throw another variable in before I'm convinced that the pipe works! - cause it's to noisy for my taste! (if it makes the power - I'll endure - but otherwise it's for sale!)
