SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Talked with a friend of mine with sidewinder and he told me to look out for your head gasket because they are starting to fail. Anyone else heard of this? Hate to think 4 yr old sled needs one already!
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Talked with a friend of mine with sidewinder and he told me to look out for your head gasket because they are starting to fail. Anyone else heard of this? Hate to think 4 yr old sled needs one already![/QUOTE
Sounds like your friend doesn't know what he is talking about. It would be next to impossible to blow the headgasket on a stock machine, maybe a severe overhead that warps the head.
TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
Please explain SideHogger I would like to hear the rest of the story.
SideHogger
- Apr 16, 2016
- upstate ny
Supposedly, the head gaskets are not holding up. Falling apart when you remove your head.
NYTurbo
Fake news
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I know a tonne of guys that ride 998's tuned and stock with over 10000++kms and yet to hear of a head gasket issue!!
Not saying it doesn't happen but it's not COMMON at all!!!
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
Geeze. Can we just ride these dam sleds! So many issues pop up here and honestly I got none. Just ride the bitch!
no1b4me
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Leave the head alone , don’t touch it just ride, The more you monkey the more you can.
TPAY243
- Apr 14, 2013
- Northern Wis
Why was the head removed you have limited info here. Was the head gasket blown before ya removed the head ??? The head gasket is usually junk after you remove the head. This seems like a very fishy story and I'm not bitting.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Did the "friend of mine" in the original post have a waterpump failure or blown heat exchanger coolant hose before head gasket?
SideHogger
- Apr 16, 2016
- upstate ny
Geeees.....didnt mean to start anything here. My friend was losing coolant and found it was head gasket leaking. The other guy doing a pro-mod build. Since TPAY243 has taken a head off before, its obvious you can't reuse head gasket and maybe I misunderstood him and thats what he was implying that they just fall apart when head removed. Again, sorry to start something that isnt a problem but just trying to keep sled as reliable as an Apex! lol
TPAY243
- Apr 14, 2013
- Northern Wis
Thanks for all the helpful information.
Turboflash
- Mar 18, 2019
- Southern MN
Also should not re-use head bolts. They are torque-to-yield just like automotive ones. Each time head is removed, should install new head bolts. Better yet, install ARP head studs for more clamp force, especially with 17+ lbs of boost.
BTW - I wish I had taken pics but when I replaced my head (warranty) I could tell by looking at the sealing lines that the head had "moved around" a little. The sealing lines (gasket lines on aluminum head and block) in some places showed evidence of minor breech. Once I installed the ARP head studs, the lines were very exact and very clear all the way around the head telling me the head was no longer "moving around." These 998s should not "use" coolant. If anyone has to top off their coolant tank periodically, and you can't find an external leak anywhere, guess where it's going? Once I installed ARP head studs, I never have to add any coolant ever.
TPAY243
- Apr 14, 2013
- Northern Wis
So how many PSI is the stock head gasket designed to hold. If you up your boost from stock PSI you shouldn't really be saying there is a problem with stock components. On the other hand if the head gasket is leaking with stock boost there may be a problem.
