Header install?
WINDER1987
Upstate NY
Hey guys i just got my mbrp header in any tips on the installation cause there was no directions I assume u take the seat and gas tank off?
Also should I replace or need any new gaskets?
Pretty straight forward. Pull seat, heat shield, muffler and tank, undo the 2 hanger hex bolts 5mm. Open up the hot box where the flex joints are and undo clamps. I did remove the exhaust outlets on the motor to make it easier. I would replace the flex pipe donuts with copper ones. That way it will be a long time before you have to go back in there.
