RtxViper
- Feb 24, 2007
- Deerfield, Wisconsin
- 2019 SRX LE
Anyone know if ther is a headlight adjust up and down? I have the sled start hids the low beam is right on the ground and high beam is not quite high enough. I find my self driving beyond the headlights and I don't care for that.
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
- ramody44@yahoo.com
To get to the adjustment screw, you have to take the body piece off that goes around the handlebar, and then look to the right of the backside of the headlight.
ecopter
Take the left hand side panel off. It's easiest if you remove the clutch cover. Reach in with your right hand while holding a small philips head driver (stubby one), and turn the adjuster clockwise to raise, counterclockwise to lower.
Jon
Jon
steve barber
I have the same thing, can I set the low beam higher and the high beam lower or is their only one adj. srcew
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
yes only one screw you can either adjust high beam to the desired hight or get the hid's some have tried shiming the bulbs out to make them closer but i belive the general findings was that wasn't working as it decreased the distance the lights would shine. on my 07 i like it with the high beam adjusted and only run low's during the day or when oncomming traffic apears.steve barber said:I have the same thing, can I set the low beam higher and the high beam lower or is their only one adj. srcew
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
get ur highs adjusted and dont worry about the lows u dont use them at night anyways exept for a few seconds if other sleds are coming, if ur not a jag and leave ur brights on when other sleds are coming.......thor452 said:yes only one screw you can either adjust high beam to the desired hight or get the hid's some have tried shiming the bulbs out to make them closer but i belive the general findings was that wasn't working as it decreased the distance the lights would shine. on my 07 i like it with the high beam adjusted and only run low's during the day or when oncomming traffic apears.steve barber said:I have the same thing, can I set the low beam higher and the high beam lower or is their only one adj. srcew
RtxViper
- Feb 24, 2007
- 2019 SRX LE
raginyamaha said:get ur highs adjusted and dont worry about the lows u dont use them at night anyways exept for a few seconds if other sleds are coming, if ur not a jag and leave ur brights on when other sleds are coming.......thor452 said:yes only one screw you can either adjust high beam to the desired hight or get the hid's some have tried shiming the bulbs out to make them closer but i belive the general findings was that wasn't working as it decreased the distance the lights would shine. on my 07 i like it with the high beam adjusted and only run low's during the day or when oncomming traffic apears.steve barber said:I have the same thing, can I set the low beam higher and the high beam lower or is their only one adj. srcew![]()
thanks for the info no I turn my brights off when oncoming sleds unless there arctic cats
