Headlight adjustment
Rikar
Before I start taking apart my 600 piece RTX puzzle, can someone tell me how to adjust the headlight. My dims point to where my brights should be and my brights point into the trees?
Rikar
Sounds like your headlight assembly was installed incorrectly by your dealer. A few guys had that problem. I'd suggest doing a search for "headlight", I believe someone even posted photos.
Most likely your entire headlight/gauge/windshield assembly is improperly installed. Really easy to fix.
Remove the top and side panels
Unscrew the two bolts that hold the assembly on
The assembly should slide onto two plastic tabs that align it properly. There is a picture in the manual somewhere.
I'm guessing that your assembly is sitting on TOP of those tabs.
hope this helps...
Same problem here, not to difficult to fix. Would have been nice for the dealership to install this properly, but sounds like it occured often.
Hard to drive at night when low beam barely touches the ground, then when accelerating you get a nice view of the stars!
My headlight pod was installed correctly (because I took it off to put in Silverstars). I just needed to adjust then down a little bit. It's really easy to do. Remove top cover and there is a phillips head screw that you turn to adjust up or down.
