Newfie Apex
- Mar 3, 2010
- Mt. Pearl Newfoundland
- 2008 Nytro
Anyone run a higher wattage headlight bulb...I was given a set of 90/100watt blue bulbs..is there any issues with running these bulbs..Referring to the stator of robbing power from the handgrips
SRX Boy
Did that with my 2006 Apex - the bulbs got so hot that they started to melt the plastic connection - I ran them for about a year and half then next time I had to change the oil I notice the damage. They were still working fine but I chose to be safe. I decided to install HIDs - well worth the investment - if you do it, buy them from the the fellow on this site who makes them (actually sells them to Yamaha you can see them in the Yamaha accesory book).
ZapeX2
Personally I wouldn't.... Stock are 55 watts, remember that the headlight housing is plastic..... might melt.... If you're gonna upgrade headlights,, go hid.. I just got in from installing mine... niiiiice.........
Newfie Apex
- Mar 3, 2010
- 2008 Nytro
bulbs
I am not going to use them...My buddy gave them to me ...he had them in his 40th Apex (Phazernut) He never had an issue...But I was concerned and thought I should ask...I got my answer
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
you can buy from PIAA bulbs that are the same watts as stock55/60 but put out 100/130 they work great and don't wax out the stator system .
