thunderbolt
If you are using your stock heat shields on your Turbo Dynamics Quite muffler , I herd that you should not put the insulation back on , because of a heat issue can some one explain ?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Ben says it will prematurely wear out the muffler.
thunderbolt
Thanks so much makes senseBen says it will prematurely wear out the muffler.
