Lonerider
- Feb 26, 2010
- south west mi
- 04 rx1, 05 Warrior 06 Attak-w/yamacharger, 07 Attak-Supercharged, 17 Sidewinder TD power trail
I am looking to add heat to my seat, I am looking for a cheeper method than a kit. I need a ohm reading on a sidewinder with a heated seat on the heat element only. I have the readings on the factory switch already. Any other info is welcome. ( the kits I see are for vipers for 300$)
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
BRP Renegade mxz 800
Seen some kits on ebay for a lot less
alain langlois
- Feb 7, 2020
- Quebec
- sidewinder ltx dx 2018
Is there any resistance in the original heated switch, if yes do have have the value?
Thank
Thank
Turboflash
- Mar 18, 2019
- Southern MN
From Service Manual:
Testing Seat Heater
Switches
NOTE: The seat heater elements cannot be tested.
Testing Seat Heater
Switches
ksiesel
- Mar 25, 2016
- Columbus, Indiana
- 2015 Viper RTX-DX with QS3’s, winder jackshaft, RR front arm shaft, 4 wheel kit, and many more upgrades
- Columbus, Indiana
The reason they say the seat element cant’ be tested is that the heater controller is in the seat and does not have a connector that would allow easy access to the element wires. The sled feeds power, ground, and a reference voltage from the switch to that controller through the connector you unplug when you remove the seat.
