Heavy Hitters!
RXONE
St. Lawrence Valley, Northern N.Y.
I have tried what seems like every possible combination with my Heavy Hitters and I just can't seem to make this RX-1 run. Whats up with that? Am I running the right weigh HH's? I have the 48.7 gram set. Is this the same set everyone is using in they're RX-1's? I've gone back to the stock weights for now until I can figure out what's going on.Thanks
Get a 54/42 Dalton or a 48/40 advantedge helix & I will tell you exactly how to make either helix work. The Advantedge actually takes 4 grams less then the Dalton to pull the same rpm,s but either one works well.
I thought you said that thing was eating up the competition and running 100mph in 600ft. Sounds like it was running pretty good to me. What gives?
Took the MBRP can off my F5 and sold it as I lost hp with it. Spoke with others and they found the same thing, besides the noise was a nuisance.
Dalton helix
A good place to start would be 6-1 or 6-2.
