RXONE
- Oct 10, 2003
- St. Lawrence Valley, Northern N.Y.
I have tried what seems like every possible combination with my Heavy Hitters and I just can't seem to make this RX-1 run. Whats up with that? Am I running the right weigh HH's? I have the 48.7 gram set. Is this the same set everyone is using in they're RX-1's? I've gone back to the stock weights for now until I can figure out what's going on.Thanks
Turk
Tech Advisor
Get a 54/42 Dalton or a 48/40 advantedge helix & I will tell you exactly how to make either helix work. The Advantedge actually takes 4 grams less then the Dalton to pull the same rpm,s but either one works well.
RXONE
- Oct 10, 2003
Turk!
I'll be testing this coming week. The problem is I can't seem to make it pull in the midrange Tom. Yeah I'll be catching up with you for sure Thanks!
192 Woodys
Also try Matt at the speedshop, worked for me.
I thought you said that thing was eating up the competition and running 100mph in 600ft. Sounds like it was running pretty good to me. What gives?
RXONE
- Oct 10, 2003
It just does'nt seem to pull in the mid-range.. I don't know! I'm wondering if it has something to do with the MBRP can.
jimmie d
Took the MBRP can off my F5 and sold it as I lost hp with it. Spoke with others and they found the same thing, besides the noise was a nuisance.
Blue shadow
What gearing are you running?
Canadian Rx-1
Daltons
Where do you put the spring on the Dalton Helix? Stock setting or???
Buckeye
- Lakes Region, NH
Dalton helix
A good place to start would be 6-1 or 6-2.
