Heavy ice buildup on tunnel OUTSIDE!
left side! Exhaust? It coming from underneath where the heat exchanger is, ice buildup melts and leaks through
Me neither. I do get it up front somewhat on the grill/nose, however. Going to try the silicone spray trick, though.
Tried silicone, doesn't work!
I was told to try Fluid Film, bought some but haven't tried it yet!
If that doesn't work I'll try Dupont teflon coat.
I'll find out in another hour I guess.
Had the same problem on my 03 F7 and ended up removing the seat and resealing the heat exchanger to the tunnel.
