Stigapex
Suspended
Hello
The snow has just arrived after a long summer, so its time to think about the sled again. I'm not satisfied with the supertips weight when I'm driving with more than 18 psi. After reading some in this forum, I found that the Heel clicker 2 speed would be better. Where is the best place to order this weights ?
Trond Lundberg (Alta Racing) eller Stian Heitmann kan ha inne i Alta
mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
- Sidewinder MTX 240 Tune Sidewinder XTX 240 Tune MountainMax SL 153.
Richmotorsports.com
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
Just so you know the turbo 2 speed weights do NOT allow for side washers to be used on Yamaha primary clutches. Sort of disappointing. My guess is they were developed for cat and then optional use for Turbo Yamaha applications if choose to run without washers. I have a brand new set if you are interested.
