scott boddie
- Dec 17, 2003
- braintree mass.
- 04 WARRIOR
has any one used heel clicker 2 speed clutch i just got my kit installed but no snow anybody use this yet what do you think any good or what
peakperf
- Oct 1, 2003
- Hayward Wisconsin
- 1972 GP292, 1972 GP433, 1972 GP643, 2003 RX1, 2007 Phazer GT
I have run them for 1 season and they work great after you get them dialed in. I run cams at 10800 so I had to grind away and ended up around 53 grams. Once I added the Rigid secondary the clutching really came together. Best setup by far and rarely get beat. Stays ahead of Mach Z's to 110 or so.
Scott
Scott
Resse
- Jan 11, 2004
Peakperf:
I tried the two speed weights last year, they seem to run ok----but the RPM's were much higher at "cruising" speed, max RPM's were 10200, and engagement was about 4400. Did you notice the higher creise RPM's?
ptt
Guest
2-speeds
What was your set up springs, wt placement and helix angle?
