heel clicker 50-20 weight problems??
lrioux
Iroquois Falls, On, Canada
hey guys,
Just tried to install my 50-20's on my nytro and the washers on either side of the weight dont fit, are you supposed to run without those washers with these weights??
Also the shoulder that the weight pivots on fits way too tight, does not pivot freely...?
any ideas of what is going on?
thanks
They should have come with thin metal washers. You may have the wrong ones. The stock washers are ok to use. Sometimes the heel can be tight but it will loosen up over time.
these weights must be the wrong ones, my weight pin is so tight that it wont even go through the weight!!!!!!!! :o| tried calling company and no answer. part number i got on the box is STS3YAM 50-20RG, can anyone confirm this part number?
I had one weight i actually had to get a file to remove some bushing material to make the pin fit.
