Wartsnuff
Hello Everyone!
i was hoping some guru's here could lend me some advise !
I friend gave me a Heel Clicker Kit P/N STS3HC92-11Y, i believe the kit to be a little old... say 04 ?
anyhow i also beleive it was bought for a 04 RX1 warrior
and i own a 07 Apex RTX
I am presuming this Kit is no good for my machine..
but i thought i would ask!
cheers
cheers
Turk
Tech Advisor
Won,t work & I will give ya $10 for it. It works in the Apex but will need some dialing in. Start with 5 grams heel & 4 in tip. If you don,t want it or know how to tune make me an offer to take it off your hands.
Wartsnuff
Turk said:Won,t work & I will give ya $10 for it. It works in the Apex but will need some dialing in. Start with 5 grams heel & 4 in tip. If you don,t want it or know how to tune make me an offer to take it off your hands.
Turk thanks for the information..
but i am a little unsure of what you are saying ?
you are saying the kit won't work and if i am to monkey with the clutch start with adding 5 grams and 4 gr in the tip ? but nothing to do with this kit ?
thanks
Dave
- Jun 28, 2004
- Clinton, Wi.
HEY TURK, you drinkin a little this morning
LOLOLOLOLOL!!
DaVe
LOLOLOLOLOL!!DaVe
Turk
Tech Advisor
Kit will work with some monkeying around.Start there & see what rpm,s are. I will buy it from you if you don,t want to monkey around with it. Fridays are allways a snowday for salesman & it,s happy hour somewhere in the world.
- Jun 28, 2004
- Clinton, Wi.
I KNEW IT!!
Wartsnuff
thanks very much guys,
not sure if i am going to monkey around or not.
need to investigate tools needed. not sure what clutch tools i need if any.
cheers
Dave
cheers
Dave
Charged RTX
It makes a huge difference what kit you have. If it is an 04 kit it is probably an early 40-20. There can be a 6 gm difference in the 40-20 from one year to the next. I think you will be closer whith the white spring and 4-5 gm in the heel only.
Wartsnuff
Charged RTX said:It makes a huge difference what kit you have. If it is an 04 kit it is probably an early 40-20. There can be a 6 gm difference in the 40-20 from one year to the next. I think you will be closer whith the white spring and 4-5 gm in the heel only.
hey there, i am not sure what the wieghts are but there is a white and grey spring in the box
it seems to say for a RX1 use the white spring, and 5.4grams in the shoulder and 6 grams in the tip?
does this seem like a resonable start ?
cheers
Dave
1000 stroker
- Sep 30, 2006
- Zeeland MI
- www.jasonbakker.com
Are they hammer time/ speed weights with the pivoting heel? If so, I can probably tell you what they are based on my experience with them. I was told that if they are all black (wieght and shoulder), and the area on the weight where the screws are added are milled out, they are a 40-20. If all black and that area is not machined out, they are a 50-20. Not sure what the 40-20 looks like. Hope this helps.
