CANAM 4 Stroker
- Oct 26, 2005
- www.klim.com
- 2009 Yamaha Apex GT
New
Help.
I've run a Heel Kicker kit in my 2009 GT, along with Ulmer bottom airbox mod , PC & a top gear of 23. And of course studs. I've been frustrated since day one by the lack of top end that my clucth set up allows me. I'm done chasing it. The sleds runs 10,800-900, and pulls hard till about 100. Then it lays down.
The only question remaining is whether I just go back to stock or give a Ulmer kit a final try. Can I get some advise from those that have been between stock and the Ulmer kit, on their ability to keep top end at stock or better. ?
Other advise is always welcome.
Help.
chris189
- Nov 27, 2011
- Hanover Ontario
- 2007 Apex GT, 1980 Enticer 340
I am looking forward to your feedback. My 2007 is all stock but compared to the srx I came from, this Apex is the same as you are describing. It just seems to rev and not go anywhere past 100. I look forward to your feedback if you get an Ulmer kit.
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700, 2023 Polaris Boost VR-129
- Niles, Oh
I have no experience with the heel-clicker setup but I can tell you the Ulmer kit in my 06 gt rocks. I have seen 130 mph on the dreameter with 24-40 gearing. My mods our in my signature. If you are only seeing 100 sounds like you could possibly have another issue. Mine still pulls very hard at 100 indicated.
dmaxx
- Apr 5, 2006
- sw Michigan
- 2014 Apex XTX, 2012 Apex SE, 2000 Vmax 700, 2000 AC Z-370, fast
- White Pigeon, MI
What kit are you running? Sounds like its all in your set up. I have the Drag n fly and air box mod have no problem seeing 115 gps on short runs.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
care to share your setup bought a set haven't tried yet. mine came with a black primaryWhat kit are you running? Sounds like its all in your set up. I have the Drag n fly and air box mod have no problem seeing 115 gps on short runs.
My Attak has shown 125 on the dream meter with air box mod, Ulmer clutch kit, Excel rear exhaust, 1.25 stock Ripsaw with 108 studs down the middle and stock gearing (23 top).
What are you looking for ? More top speed or more pull to 110?? The 23 top gear will get you t0 100 quick but will stop pulling soon after that. I have found that on my sled with stock and aftermarket clutching.
With the Ulmer kit the "get up & go" is be better than stock.
CANAM 4 Stroker
- Oct 26, 2005
- www.klim.com
Thanks for the input guys. I believe I will go with Ulmer kits and take the gear back to 24. Don't like being snowed on the long stretches. I'll let you know what I get. And hope to make the change in two steps to quantify the differences to clutch kit or gear
chris189
- Nov 27, 2011
- Hanover Ontario
Look forward to your results!
