HELP! 1000 FT DRAG SETUP
BLACK JOHN AND TURK, THANKS FOR THE REPLIES, I AGREE WITH YOUR GEARING RECOMMENDATION, IT IS PULLING MUCH BETTER AND I WILL LOOK AT THE CLEARANCE ON THE PRIMARY.
MUST GO DODGE SOME MORE MOOSE.
PETE :wink:
Just some more results on this topic. I have an 03 rx1 w/cpr stage 3 clutching, and top gear down 1 tooth. ECP kit also. I have 192 carbide studs and weigh 175 dressed. I ran 97 mph in a 1000 ft ice track. I'm a little dissapointed. I have to agree that the ecp kit does affect top speed. What do you guys think? What are you running in a 1000ft, w/what mods? Thanks, Bill
1000 ft
check your comprsion i did when i got those speeds :( not good it should be about 205-206 thats were mine used to be now its 178-179 my buddys is ever lower
Bill,
97 mph sounds pretty good. I just got back from a 1000ft radar run and ran 95 mph. I have clutch work and hauk filters. There were no other
RX-1s to compare. However last weekend I ran a 660ft radar run and got 82 mph, a stock rx-1 got 76, and a stock warrior could only muster 70 mph. Oh yea, there was one with a turbo, he was running 89-90mph.
