Help!! 2008 nytro Flooding problem
mpaine
I have a 2008 nytro xtx that a mouse got a hold of over the summer.. chewed cyl.2 injector harness and intake air pressue harness. Replaced harness and when that didnt fix it i replaced both sensors. It has been dumping raw fuel out the exhaust like as if the injectors are wide open.
I pulled entire harness out and checked for any other problems and couldnt find any. Put her back together and finally got a check engine light for the intake pressure. Both Sensors are reading at 100. ( i believe is should be around 14)
Im running out of ideas other than maybe the ecu fried when the wires were broken.
Any help would be greatly appreciated
Mike
