help changing the pto side jackshaft bearing
copo427ss
elma, new york
just a couple of questions. do i have to take apart the chaincase and slide the shaft out to remove the bearing on the pto side? or is there a trick to getting it apart? it looks as though there is a compression lock holding it tight on the inner bearing race.
on the first few pages in this specific forum you can find a post with a link to down load your own FREE service manual for an apex-attack.
there is specific instructions on the disassembly and reassembly of what you are asking about.
i also think you can find this info in the tech section but i don't think it is as specific as the manual
Hope this helps
thanks. i had access to the dealer site and i downloaded and printed the service manual but all that was on there was the supplement manual. go figure. i'll check it out
You have to remove the jackshaft from the chaincase to do the bearing............search the Tech section there is a good tutorial there. One caveat...........be careful removing the shaft as there is a spacer and washer behind the chaincase that will fall off when you slide the shaft out. I found out the hard way. It's hard to see on the fiche but I used a pole to follow the shaft out and catch the washer/spacer.
