rindtj
Okay, so I was out riding after the 2.5 inch DUMPING hear last night...lol. On take-off there was a sort of clunking sound under the engine. First thought was maybe the track was slipping and too loose. Chain maybe, but it was only when I really punched it. Any other ideas/experiences?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Sounds like track ratchet f it happens from a holeshot. Just tighten the track.
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Mono skid? Transfer rod possibly.
rindtj
We were thinking track ratchet too.
It is the mono, but the transfer rod looks fine? What would happen to it? It only happens when I pop the skis, transfer rod is only set at one graduation toward max from neutral
zeke
clunking
you probably would only hear the transfer rod when going slow over bumps. if it is when you crack it and wheely with good traction it would be the track slipping.
Crewchief47
- Jan 16, 2006
At any rate, you can usually hear and FEEL a ratchet, the transfer thing is mostly just a noise you hear. Which applies to you?
Super Sled
- Feb 25, 2009
- Summit X
KnappAttack said:Sounds like track ratchet f it happens from a holeshot. Just tighten the track.
if only at take off, I bet this is your culprit. Did you just put new dually carbides on by any chance? If youir skis are gripping/digging in then sometimes the track slipping is less resistance then moving the sled, if you catch my drift.....
Dano
worse case scenario could be from the chaincase if a bearing is starting to let go or gone, which loosens the chain up to skip. Regardless, you can usually narrow it down by the feel of the clunk, whether it be felt through tunnel or bars.
Dan
Dan
rindtj
Thanks for all the advice, will be checking all three of the suggestions, crossing my fingers hoping its just the ratchet..
catchmeifucan
my attak ratcheted all the time when traction was good and the skis pulled. no matter how tight the track i would get it on takeoff. i ended going to antiratchet drivers but even then, with good hookup, i would still ratchet. problem imho is the approach angle. it is no longer a problem to me, as i went to a sc4 suspension, and i can now run my track a lot looser.
CaptCaper
- Jan 1, 2007
- Northern N.H.
- 2016 RS Vector XTX 1.25 Lug .2013 RS Vector LTX. Past Machines 3-2007 Attaks 1-2010 Vector LTX.. 2- 2003 VMax 600ER's.
- New Hampshire
I thought I read lot's of post's in the past on this subject. The transfer rod is on the top of my list. Normal for our machine. I get the same thing going over moguals slow. Been this way since new. Got 5k miles now and suspension is still good so don't sweat it yet. Take some time and search to isolate it more.
Super Sled
- Feb 25, 2009
- Summit X
Guys, remember he said it clunks on take off. I'd bet dollars to donuts its the track ratcheting.
Fixes are tightening the track or switching to extro drivers.
catchmeifucan
more info needed. it appears a track ratchet to me as i earlier said, but, 2.5" on takeoff, ?????
Did it hook up solid, lift skis in air-------------if so, track ratchet, if not, another problem.
mr.pitstop
take off=track ratchet (tighten track, inspect drivers)
slow over bumps= transfer rod (normal)
rindtj
2.5 inches of snow, skis were about two feet off the ground. I would say it is the ratchet. Getting a scale this week to check how tight the track is. Thanks guys.
