MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
I wear an MX helmet and goggles.
I have the 509 Sinister goggles http://www.509films.com/optics/new/
My eyes freeze! I get so much wind around my eyes that they water.
Any ideas?! I have the grandpa windshield too!!! Anyone else use these goggles?
Thanks guys,
Thanks guys,
marpolsdofer
It possble you letting to much mostier in but not out. You can buy a breath box itwill cover over your mouth and nose to deflect your breathing down. If you cheap you can use tape or you can by this specail strips that do the same thing. The tape and the strip to go over the nose then bridge to the helmet. The breath box go inside the helmet over your nose. I have use tape to secure my balaclava to my face (so it dont move down), then the stips to the helmet becaues it wont need to be cut to size. I have the breath box to but never use it. I found itrides on the nose right were my googles sit and it pushes down my balaclava.
I use scoots motocross googles for over cast day (almost like the hustels), they are clear but have a bluish tint when you were them. Sunny days these http://www.steelmx.com/snow/chromeltd.html.
spike337
You can't have any leaks with the almighty 509s! lol. Do you wear a 'half mask'? I wear glasses so i actually glued some foam on and trimed a little off my goggles to seal a little better.
I fog my glasses right away with a full balcalva.
david galloway
i wear a mx helmet, scott goggles, and a thin balaclava and i have no problems.
phaze5
are you breathing heavy??????????? that could be enough moisture to help freeze ya,
i ride with a full face, with the shield open 1/2 the time with no windshield
MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
no fog problems, just WIND in my eyes!
I will try to seat my goggles better
xt_gt
david galloway said:i wear a mx helmet, scott goggles, and a thin balaclava and i have no problems.
same here.
i'd try to add something to the top ridge of the goggles. (where the foam is)
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
do you run a breath box???? i have no problems with 509 helmet, 509 goggles, and a 509 breath box..
MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
RIGIDONE said:do you run a breath box???? i have no problems with 509 helmet, 509 goggles, and a 509 breath box..
HJC Helmet, 509 Sinister goggles no breath box. I don't have any fogging issues, just wind in the eyeball.
I am going to try closing off a vent and see what happens.
Thanks guys
mitchw
- Dec 21, 2009
- Kelliher, MN
- 2010 Arctic Cat M8 Snopro
2008 Phazer MTX
2002 Tundra 300
I just bought a No-Fog mask. A buddy had told me about them, and it seems to be working fantastically, no fogging when sweating or anything like that...
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
I THINK THE BREATH BOX HELPS WITHT THE WIND GETTING INTO THE HELMET....woops sorry about the caps...thru the mouth part.. i also wear a t-shirt sleeve on my head i cut off an old t shirt and the other sleeve on my neck and chin. like a turtle neck... i also warm my goggles up with the exhaust off the sled.. just hold them infront of the pipe for a miniute or two
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
RIGIDONE said:i also wear a t-shirt sleeve on my head i cut off an old t shirt and the other sleeve on my neck and chin. like a turtle neck...
And you wanna hook up with me for a ride this Winter???
They do make these things called "turtle fur" with a balaclava sewn into it, save your shirts!!! LOL
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
porkchop said:RIGIDONE said:i also wear a t-shirt sleeve on my head i cut off an old t shirt and the other sleeve on my neck and chin. like a turtle neck...
And you wanna hook up with me for a ride this Winter???![]()
i get free t-shirts... i also wear a blaze orange 1 piece hunting suit.. big pimp'n!!!!!! JK!!!!
spike337
Don't you guys tape up your helmets for the winter? Most are made to cool your head with forced air flow. I use foam and tape. Heck, i get popsicle lips in fall on the quad without it taped! lol.
marpolsdofer
spike337 said:Don't you guys tape up your helmets for the winter? Most are made to cool your head with forced air flow. I use foam and tape. Heck, i get popsicle lips in fall on the quad without it taped! lol.
I have tape to meat the ISSR requierments but I left all my vents uncovered.
