mx1500
so i had code "43" come up and we changed the fuse. all my keys are off,kill switch off,and the key is out but when we take the fuse in and out it sparks. we backed it out of the shop and it died. with code "12" coming up. now the fuse that used to spark doesnt spark,but it cranks over great! i need help solving this issue. thx
mx1500
something keeps burning out that 10 amp fuse that runs the fuel pump.
canuk77
The code 43 means the power to the fuel pump and injectors is not normal.I would start by following the wires to make sure there is no issues like pinched wire causing a ground.
mx1500
where is the "crankshaft position sensor" located?
Zakre
did you have the harness update done, about rubbing through near the primary clutch?
mx1500
i dont think so nope. could that be the issue? code 12 and 43 come up
mx1500
yes 4 wires rubed through near the primary clutch. fixed em,wrapped them in ducttape and a hose then ziptied them away from the clutches
Zakre
mx1500 said:yes 4 wires rubed through near the primary clutch. fixed em,wrapped them in ducttape and a hose then ziptied them away from the clutches
Very common, glad you got her goin!
