NH_Nytro
- May 15, 2011
- Colebrook, NH
- 2008 Nytro
2007 Rs Vector
As I stated my 2008 Nytro has been running fine, rode it 140 miles 2 days earlier, today it started up fine, I warmed it up and headed out, approximately 1 miles into my ride it lost power and died, the battery voltage is good, I can jump the solenoid and it will crank fine but cannot hear any fuel pump and it only cranks no start, I removed the tether kill switch from the equation, it is a plugged and play and play kill switch so no splices, all looks good, so far I checked all connectors I can see, tried a known good solenoid, replaced the main fuse as well as the other fuse in the solenoid, checked key switch connector and sprayed with cleaner but it wasn't bad, I am running out of ideas .
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
So seems to be a pump issue. Check the pump fuse and the relay. Check for power at the pump.
NH_Nytro
- May 15, 2011
- Colebrook, NH
- 2008 Nytro
2007 Rs Vector
I found the problem it ended up being a fuse in the small panel behind the brake caliper that I didn't even realize existed and could find no reference to it a 20 amp fuse was blown I replaced that and everything came back for power
onceunder
- Jan 29, 2023
- adirondacks
- 2008 Nytro
Hello I have the same issue but Im getting 7 volts at fuel pump, can a relay cause this?So seems to be a pump issue. Check the pump fuse and the relay. Check for power at the pump.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
It's possible, especially with the red electronic relays. Start tracing back from the pump. Could also be a bad ground.Hello I have the same issue but Im getting 7 volts at fuel pump, can a relay cause this?
Alex069
- Nov 6, 2019
- Moscow Region
- Russia
- Yamaha Venture Multipurpose;
FXNytro XTX
but the main idea is not only to replace the fuse, but find the reason that fuse melted. inspect the wire harness, might be a wear/abrasion somewhereI found the problem it ended up being a fuse in the small panel behind the brake caliper that I didn't even realize existed and could find no reference to it a 20 amp fuse was blown I replaced that and everything came back for power
