hi a first time poster and first time yamaha owner. i have a new rx-1 warrior [blue] i baught the plastic open idler bogey wheels [sma-bcr38-01-bl and wheel hardware kit [sma-wheel-00-kt] from yamaha . they don't seem to fit right. if you put the new bolt on inside of skidframe through the holder and wheel then nut/collar the wheel is to close to the lugs and the nut colar is not locking.if you put the bolt through skid. with nut/colar aginst outside skid,wheel,washer,original lock nut the bolt is too short ?please help an x-cat rider thank you phil
I had those same wheels on my viper!! ID take em back!! THey are junk! I destroyed the 4 front ones within a 1000 miles!! They go flat where the openings are!! and i tried to get em warrantyed and they wouldnt DO IT!!
The front ones should have the nuts on the outside and the center ones should have the nut in!! H0pe this helps! :roll:
