Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Putting on a oft relocate and the ball joint on the end of the tie rod won't slip off so I can realign skis. It's stuck
Any ideas to get it to pop off
Tried hammer, screw driver and pry, heated it, wd40
This was supposed to be a 5 min job
Now sled is down
Nice
Help
Ms
Now sled is down
Nice
Help
Ms
Why do you need to pop it off? Should be able to loosen the jam nuts on both ends and just rotate the tie rod itself to make the adjustment.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Correct. Do not remove the ball joint. The jam nuts both break in a counter clockwise (Left hand) motion while facing them.Turning the rod clockwise moves the skis to the right while facing the machine.Why do you need to pop it off? Should be able to loosen the jam nuts on both ends and just rotate the tie rod itself to make the adjustment.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
How on earth do you get at the bottom one?????????
I have the threads ruined on the ball joint so regardless it's gotta come out
Supposed to be a 5 min job, so much for that
Ms
Ms
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
You don't need to remove it but for when you do there are a couple of techniques. You can buy a tool called a pickle fork that's made for removing tapered joints or if a fork is not available you can apply pressure using a pry bar as if you were trying to pry it out and then hit the end of the piece it's pressed into with a hammer.
I made a tool out of a medium sized chisel. Just grind a notch out of the center of the chisel large enough to fit around the stud of the ball joint.
pry bar method
pry bar method
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Grizz
How hard do you rap the steering piece? Do you tap it, or really hit it?
Tried prying down with a large slotted screw driver, but no luck.
Have a pry bar that could mimick your chisel idea.
Let's just say this doesn't work, then what?
Ms
Ms
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
It'll work. give it a couple good blows with a hammer. It also helps to turn the bars so the end is facing out. If you do the pry bar method it helps to have someone pry on the joint while you hit it with a hammer. I've done that method on diesel trucks for years. I've used this method on a few sleds over the years but because some of the joints are hard to get at with a pry bar and hammer it's easier to use my modified chisel. They also make pickle fork attachments for air hammers.
Modified chisel
Modified chisel
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Grizz, you did it again. You were right!
Thanks for your help, I used a longer cold chisel to pry with and heated it up good with the heat gun.
Wish I knew this could be such an SOB.
Last night I was beside myself,
You guys wih a broad mechanical background have all the tricks.
Thanks again
Ms
Thanks again
Ms
