I screwed my fuel screws in and turn them out 2.5 turns. Sled orginally started on choke, but no throttle. It would just die.
I went back to stock with 2.0 turns and same thing, but now it wont even run with or without choke.
Any ideas what to do next? Pulled one plug and it is dry. I never removed the screw just slightly seated them. Could I have plugged something??
Anyone else have this problem??
What I have tried and checked....gas yes, primed the fuel pump with jumper, checked all hosing all intact....
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
FAMILYMAN said:I screwed my fuel screws in and turn them out 2.5 turns. Sled orginally started on choke, but no throttle. It would just die.
Pilots are clogged or way too small.
Thomas800
- Dec 17, 2004
- Fort St. John B.C. Canada
- www.snowmobiledragsters.com
Is this after sitting for the summer with fuel in the bowls? If so either plugged pilots or maybe needle a seats stuck closed with the dreaded green grung from stail gas in the bowls?
What I found was, I had to prime my fuel pump. I had the sled running, idealed good, little lean. So I decided to change the carbs and do the oil change right away.
When I did the oil change I had to removed the feed to the fuel pump. Sled wasnt getting any gas!
UMMM....maxdlx found it..not be fyi!
