help with mono shock
rxwhopper
REGINA SASK> CANADA
guys i am having problems with bottoming, i know i need the bigger springg, till then i hear of some c-clip change, i looke at my shock installed in the sled and i cant see where the clip is,. Is it under the spring preload adjuster?and how many clip positions can you go, thanks
clip is under preload adjuster, move clip up the shock body to stiffen, 3 different positions. lo, med, hi, if you will. You will need a spring compreddor capable of fitting between the coils.
