Just kitting out my apex GT anyone fitted the small wheel kit? Is it worth fitting this kit? any input would be welcomed. Pictures of one fitted would be a bonus....
rock
Do you mean the marginal snow wheel kit up front? If so, if you ride in marginal snow cover a lot it's a good idea. Also, it can't hurt and it's inexpensive.
Mounting location of marg. snow wheels
Is there a specific mounting location for the "marginal snow wheel" kit?
Anyone have pics of the wheels installed on the monoshock skid?
The Yamaha kit comes with instructions once i read these it directs you where to put them will photo them tommorrow for you
fourload
If it is similar to the kit I used to run on my srx it used to freeze up in canada when it was cold then the wheels would flat spot.
m. wheel location
I see the directions state when mounting the marginal wheels at the bend of the rail to put them directly against the rubber block, but I seen a pic in Maxx Performance's catalog which shows them a bit forward of that location-any reason for the difference?
- 7K
