Question for ya
Hi I was reading your post I notice you said you bought apex mountain seat what did you use for taillight? thanks Jerry
twomorestrokes
Re: Question for ya
Jerry, the Vector tailight bolts into the Apex seat just fine. I just need to rework the seat harness with the Vector plugs.
Mike
BIGGUY said:Hi I was reading your post I notice you said you bought apex mountain seat what did you use for taillight? thanks Jerry
Mike
twomorestrokes
Done! Thanks for the help guys!
I marked the tank and made a template like you suggested Brian. After transferring to the shroud and taping it off, I measured to make sure the two sides were semetric and compared the taped off part to DaJudge's photo. Then I cut it with a dremel tool. Easy. I sanded the edges before removing the masking tape, then untaped. I already have it put together and you can't tell that it didn't come that way! The shroud presses into the seat just enough to hide the white edge where it's cut off. The Apex seat contour lines even match the lines in the top of the shroud. What an awesome upgrade. Looks way cooler and the seating position feels great!
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
I just received my Mountain Mod seat today and hopefully I'll get into mounting it next weekend! Apparently, he is using a newer, and firmer foam.
DaJudge
- Nov 29, 2005
- West Michigan
- '06 Rage
twomorestrokes said:Yep, that's it. Looks like about 3 1/4" off at the top will do it. Thanks for the help guys!
Mike
Now remember, I used a cutoff wheel. You want to end up with about 3 1/2 inches total. Also you want to cut on a angle so you dont have a sharp edge to cut the seat. I used a die grinder to round off the edge that I cut. The most important thing is take your time, dont be in a hurry. The plastic cuts very easy.
I posted this and then saw that you had it done ......... good job.
DaJudge
- Nov 29, 2005
- West Michigan
- '06 Rage
Re: Question for ya
Jerry, do you still need/want that template? If so I'll have to send it before I go south.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Hey Twomorestrokes, did you end up cutting a connector and pulling the wiring through your old seat? Or buy a new one?
I'm in the same predicament as you were. Removing the wiring is tough. Also did you run the wiring under the heat shield that's riveted to the seat? Or do you feel secure enough that the wires won't melt from the heat off the exhaust?
twomorestrokes
I cut the connectors off the Vector seat and am making my own harness by soldering and using heat shrink. I am going to leave it outside the seat but not sure where to route it yet. Yes I worry about exhaust heat. I wonder where it is routed on mounain sleds? Anyone know?
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Hey Mike, I figured out why you were having trouble pulling on the wiring harnes in hopes of removing it in one piece.
It turns out that it is actually taped to the plastic base of the seat.
I ended up removing about a dozen staples on the side and was able to get my hand in and carefully pull the wiring with the tape off. No problem at all.
twomorestrokes
Grimm said:Hey Mike, I figured out why you were having trouble pulling on the wiring harnes in hopes of removing it in one piece.
That explains it! I have my seat sold though so I am aprehensive about pulling staples loose. Did you put your seat back together afterward?
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
twomorestrokes said:That explains it! I have my seat sold though so I am aprehensive about pulling staples loose. Did you put your seat back together afterward?
No I didn't, I figure if I ever upgrade my sled to an Apex, I'd put the Mountain Mod seat on that and put the old seat back on the Vector. Then I would transfer the wiring back as well and I'll staple it back up then.
TEMPLATE
Da Judge, Yes pls mail the template to me thanks bud. Jerry
DaJudge
- Nov 29, 2005
- West Michigan
- '06 Rage
Re: TEMPLATE
I will get it out tomorrow.
BIGGUY said:Da Judge, Yes pls mail the template to me thanks bud. Jerry![]()
