help
darv
Age
64
International Falls,minnesota
08 Apex 40th LTX
i guy gave a helx he said it is from ulmer's it has a letter G stamp on it anyone know what it is and what it is for.
Thank you.
It's likely something very close to a 51-43, but those advantedge helixs Ulmer used "act" very aggressive. It will load the motor much harder and drop RPM when compared to something like a Dalton 51-43. Typically they perform 3-4 degrees steeper than they are stamped.
Is there a small number stamped on the "inside" of the helix? The G is stamped on the outer portion, correct?
