Dilly
- Dec 29, 2019
- Minnesota
- 2020 Sidewinder LTX SE
Last night was riding and sled was running great. Then the sled started bogging and running like it was on only 2 cylinders like I fouled a plug. Got it home checked plugs and it all looked good. Put new plugs in started it up and it has a strong gas odor and seems to b only running on 2 cylinders. No codes pop up so what could it b? Any suggestions?
Was it running hot? They go into limp mode when the temp gets up around 212* No codes when this happens
Erskin
- Feb 6, 2021
- Maine
- 2021 Thundercat
265 maxspool TD SM
- Bangor
Check the intake boots and make sure all the clamps are on tight and flush.Last night was riding and sled was running great. Then the sled started bogging and running like it was on only 2 cylinders like I fouled a plug. Got it home checked plugs and it all looked good. Put new plugs in started it up and it has a strong gas odor and seems to b only running on 2 cylinders. No codes pop up so what could it b? Any suggestions?
Maybe a dead coil?
Try to determine which cylinder is dead then swap coils with another cylinder and see if the problem follows the coil.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
The gas smell would concern my. I'd check around injector area and check for any leaking . You would want gas near a hot turboLast night was riding and sled was running great. Then the sled started bogging and running like it was on only 2 cylinders like I fouled a plug. Got it home checked plugs and it all looked good. Put new plugs in started it up and it has a strong gas odor and seems to b only running on 2 cylinders. No codes pop up so what could it b? Any suggestions?
