Cable810
- Jan 25, 2018
- Rogers City
- 2015 Viper MTX MPI 190
- Rogers City Mi
Here we go again....
My viper is back to stuttering.... I can't tell if it's either a fueling issue or a spark issue.
Found two boost leaks and fixed them. Thought that was my over all issue but apparently not... went for a short rip and its still stuttering...
Seems to be typically around 5200 to 6200 rims.
Here is a youtube video when it's stuttering.
Also here is my first post relating to this issue.
Had it fixed and ran great but unfortunately ended up back in the same spot...
I've got new coils on the way cause why not. I have one coil that's Ohm reading a touch different than the other 3 coils. New plugs this year gapped at .020.
I'm also in touch with Ulmer
Viper Miss/Stutter. Wont fire on .02 Gap
After the first ride of the season I'm left with trying to get the sled running right... 2015 Viper MTX Mpi turbo. Between 5100 and 6200rpms there's a stutter and sounds like a miss. 0lbs of boost at around 40-45mph i get a constant stutters and sounds like it's missing as well. Once I get...
ty4stroke.com
