stomper
On my wifes 06 Attack (efi) there is a slight hesitation Right out of the hole while excelerating. It is also there if I am going slow and then hit the gas. It is good once I get going. It just boggs for a couple second right off the start then takes off. Just wondering if this would be a simple adjustment issue or something bigger.
07apexcan
Possible fuel richen needed though the cluster search co adjustment
wileya
- Nov 30, 2009
- Forest, Ontario
- 15 sr viper rtx se
07apexcan said:Possible fuel richen needed though the cluster search co adjustment
X2
marq
- Apr 14, 2003
- Bridgman, MI
- 2006 Apex RTX
The instructions for the CO Adjustment can be found on Ulmer Racing's website, under Instructions / Stealth Air Box
www.ulmerracing.com
www.ulmerracing.com
Capt.Storm
EDIT below...double post.
Capt.Storm
Can also be bad doughnuts..mine was just starting to do that..then the back firing came.
I only found two sorta half pieces left.
And my pipes were wore through from the clamps..one slot on each set.
Ak Yammy
New belt cured mine.
Super Sled
- Feb 25, 2009
- Summit X
Do you have any mods on the sled? Did the hesitation start with the addition of any new mods?
If not, another thought is bad gas.
studboy99
- Sep 25, 2011
My 06 Apex GT was doing that and I cured it with a spark plug change.
~Jim
~Jim
stomper
Donuts are good, sled stalls almost immedetly when I plug the exhaust. Could possibly be the belt. I just bought the sled last spring and this is the first year that I have drove it, so I don't know the last time it was changed. I tried my spare from my rx1 and it made no difference, but it it is just my spare and it is used also. So I will try the CO adjustment and see what happens. If that doesn;t work I will purchase a new belt, shold get one anyways.
stomper
As for belts, is it best to stick with OEM yamaha brand belts.
yes.stomper said:As for belts, is it best to stick with OEM yamaha brand belts.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Change the fuel and plugs before adjusting the injection system.
