paltor
So i have a 2009 nytro mtx....I would like to put turbo on around the 200 210 hp range....can i get away running pump gas without head shim...or should i think about shim?
ulmar turbo makes kit without shim...
thanks shaun......
thanks shaun......
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
Mcxpress 180 Hp kitt dont need thicker headshim,wonderful trottleresponse and runs on pump gas.
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
paltor said:So i have a 2009 nytro mtx....I would like to put turbo on around the 200 210 hp range....can i get away running pump gas without head shim...or should i think about shim?
thanks shaun......
Yes, you can run 8lbs or 210hp, 93 octane with stock compression at sea level. Also you could add lucas octane boost to get the octane up to around 98 just to be on the safe side.
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
Full Power Performance came out with their stage1 triple intercooled Nytro turbo, 200HP @ 7 lbs on pump gas without a headshim. It's a complete bolt-on rear mount kit using the stock exhaust headers and fuel tank and I think it's gonna be priced around $4000.
http://www.ty4stroke.com/viewtopic.php?t=87839&start=0
- 6K
