High beam indicator stays on 06 Rage
RageX2
central wisconsin
while riding i noticed my high beam indicator was on and stays on. i can hear the relay clicking and both beams work. low beam indicator is dim, high beam it's bright as normal. looked for worn wires etc. but found none. anybody ever hear of this?
Did you try it again after this happened? It might of been just a little mess up and it just re-booted itsself?
after switching relays from my wife's Rage, there was no change. turns out one headlight bulb was bad. have never seen such a thing in 32 years of life with sleds . i overlooked the obvious place to start diagnosing. oh, a least it cheap & easy.
