Hooked Handlebars
wryan_garner4
Earlton, Ontario, Canada
any one know where i can get a decent set of hooked
handlebars for my mountain? i thought about going with
the fx bars. would this work? a riser and pivot would also
be nice. any suggestions?
:yam:
Instead of getting a 2" riser, one could install some alum, handle bars with maybe a CR-high bend in them... That would bring up the bars quite a bit, seeing as stock bars have almost no upward bend in them.
That's what I wanted to try, would be lighter and clean looking.
Only thing is that the grip warmers look riveted on... do they remove easily?
I got some bars off an 06 vector Mtn. They work perfect, and the hand warmers plug right in. Also they have a higher bend than the mtn lite bars do.
Phazed.... what about the brake cables, does it look like there is some extra slack in them? I want to probalbly add 3-4" compared to the stock height. I've got a pivot block, 9" risers and pro taper bars going on mine.
The Brake line seemed to have plenty more slack, I wasn't interested in looking for anymore once I saw it would work.
The brake line can be slightly rerouted from what I could see in that little engine bay.
The throttle cable pretty much, goes straight down
to the throttle body.
Its quite the process to get in there to see what your working on. Who would have thought you'd have to remove your seat to install a bar riser...
When I get My 07 update Attak bars I'm going to put them on the Mtn Lite. I don't need the suicide strap ahhhhhh? I mean mountain strap. I'll have hooks and probably gain about a inch in height over the stock Mtn. Lite bars.
2 inches is about all you'll get with the throttle.(and you have to reroute the cable under the bar instead of the stock "over the bar" location
The others are fine.
