wayfastkev
I remove only the bearing retainer on the left side. Loosen the set screws that are on that bearing. I dont even mess with the bearing on the gear box side. It will slide ride out.
I also unload the rear supension by unhooking the rear torsion springs and unscrew the the front spring retainer so you can pull out the top spring retainer. Then you can collapse the rear supsension and it makes it real easy pulling it out and stuffing it back in. Thats my two cents thou.
