How do you bypass tors on 05 Vector
  • Thread starter Thread starter Al
  • Start date Start date
look under the handle bar pad and you'll see the wires running to the throttle block. if memory serves i believe it's a blue and blue w/yellow stripe that you tie together
There is a recall on thecdi that was messing up the tors.
I just had my cdi unit changed. Took the dealer about 40 minutes and I was good to go.. MM. ;)!
Al said:
How do you bypass tors switch on 05 vector?
It's in the manual, page 9-1. If you don't have it, you can view the manual online at
http://www.yamaha-motor.com/sport/servi ... x?ls=sport
Here's the graphic
