How do you install the aluminum oil filter adapter that pumps oil to the turbo? Im thinking I have to screw out the brass threded tube that the oil filter screws onto and replace it with the one that came with the adapter and the adapter its self but im not sure how to do that.
You will have to use vice grips to remove the old brass fitting. You will probably ruin it getting it out. If I remember correctly there is not much of an area without treads to grab onto.
