02xtreme
Final trip last year my electric visor wasn't working. I'm fairly sure it was the cord on the sled. How do I test it to see if its working?
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
02xtreme said:Final trip last year my electric visor wasn't working. I'm fairly sure it was the cord on the sled. How do I test it to see if its working?
It should have a fuse or did you install it without one?
Not sure about other ways, but I have seen/used a small test plug which lights up when your connection is good.
I believe my bud purchased it at Royal Distributing?
CaptCaper
- Jan 1, 2007
- Northern N.H.
- 2016 RS Vector XTX 1.25 Lug .2013 RS Vector LTX. Past Machines 3-2007 Attaks 1-2010 Vector LTX.. 2- 2003 VMax 600ER's.
- New Hampshire
12 v bulb with + amd - leads to leads of shield wireing. Or test light bought at walmart for cheap money or a volt meter digital is best. Don't forget to wiggle the wires to make sure it's solid.
02xtreme
CaptCaper said:12 v bulb with + amd - leads to leads of shield wireing. Or test light bought at walmart for cheap money or a volt meter digital is best. Don't forget to wiggle the wires to make sure it's solid.
I have a test light. What should the voltage read?
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Over 12v. Put the red test probe to the center terminal of the plug and the black to ground and it should indicate battery voltage. Test lights do not indicate voltage, it has a light. A multi meter will show voltage. If there is no voltage check the fuse in the fuse box on the right side. If that is OK then check the ground circuit, multi meter on ohms, put the test probe on the side contact of the plug and the other to ground. If that indicates OK then the problem is in the cord or the visor.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I thought it was my cord when it was the sleds fuse that was burned out. I even bought a new helmet and E shield. The buddy pointed out the fuse was the issue
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
Replace that 3 amp fuse with a 5 amp. I had trouble with mine until I did that.
yamadoo
- Jun 3, 2003
Same thing here. Went to 5 amp fuse.
CaptCaper
- Jan 1, 2007
- Northern N.H.
- New Hampshire
yamadoo said:Same thing here. Went to 5 amp fuse.
+2 put a 5 amp fuse in
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
This happened to me last year and I found a broken wire in the plastic housing where they go into the visor. I also learned that you won't find full continuity through the visor, there is a conductive coating on the lens that heats up when the voltage is applied but I'm not sure what the resistance reading should be.
canadianhunter
Finished tester on left, rest is parts to make it.
Use tester alot for on other sledders cords, shields and sleds.
wkeggenhoff
- Dec 20, 2007
- Ajax,Onatrio, Canada
- 2006 Yamaha Apex RTX
I blow this fuse all the time when cord comes undone while riding and centre pin strikes ground on chassis.
Read somewhere that you change polarity of the shiel hook up and opuit the ground wire to the centre pin and posistive wire to the outer shield.
The heated visor does not care about polarity. But be carful if you switch polarity on 12 volt acc. plug if you plug phone charger, gps, etc into it copuld affect them.
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
wkeggenhoff said:I blow this fuse all the time when cord comes undone while riding and centre pin strikes ground on chassis.
X2
I did that and it fixed the problem.
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
heat exchange
THKSNOW said:I spliced a blue LED into the cord, always know when there is power. Click on picture to enlarge.
I saw cords at a skidoo dealer that lit like that.They were to much money for me but a great idea.How did you wire it in?
