Buckeye
- Lakes Region, NH
mms057 said:are you guys putting any sealer in between these gaskets????
mag
If they are new the heat should bond them together. If not then I would use the copper spray adhesive.
Yammerhead
Buckeye said:mms057 said:are you guys putting any sealer in between these gaskets????
mag
On my Go-Kart race engine (Honda 4 Stroke) I didn't have very good luck with the copper spray. Switched to Hylomar Universal Blue and is works WAY better. Not sure if it would do for this application, but I know it works slick for my kart.
http://www.hylomar.co.uk
I see they even make a racing formula. I have used the Universal blue and aircraft grade. I can get the Universal Blue at a one of the big hardware chain stores.
mms057
- Sep 8, 2004
- NY
- www.magnumjetsports.com
like a home depot of a lowes????Yammerhead said:Buckeye said:mms057 said:are you guys putting any sealer in between these gaskets????
mag
mag
adirondac blue
I would like to get some of the racing formula, but were do you get this stuff.
Jack_Shaft
I'll assume that the guys running 10:1 pistons do NOT need to run 3x gaskets for 20-ish lbs of boost...?
-JS
-JS
SuperDave
- Aug 28, 2003
- Sicamous, BC Canada
- www.powderlites.com
head gaskets
I have shim made for RX1 and vector and selling now.
Dave@ http://www.powderlites.com
I am running 14 lbs boost on pump fuel with Vector
mms057
- Sep 8, 2004
- NY
Dave.... missin a hole for a 4 banger!!!!
gaskets???
14 psi w/stock pistons???
mag
gaskets???
mag
Yammerhead
adirondak blue said:I would like to get some of the racing formula, but were do you get this stuff.
Canadian Tire is where I got my last tube of it, but I don't think that helps you Yanks out. Permatex makes a version of the stuff, check out their website.
http://www.permatex.com/heavy_duty/Engi ... m_no=25249
I know guys get the aircraft grade stuff from aircraft maintenance shops at the airport.
adirondac blue
You can order their products, 1-877-hylomar, located in illinios
woodsrider
- Feb 17, 2005
- Lewiston, ID
- 2017 YZ450FX1 Moto-Trax 137 Mountain Kit
Hardcore -your one sick puppy! Your streaming video almost made me loose my lunch. Go see a dr.
Oh by the way I'm running 14# on 50/50 of 92/110 octane with stock motor.
lancef53
So with 3 gaskets and 92 fuel, what is a safe PSI number? The stock gaskets are .030, right?
Dave--Do you use 2 stock gaskets with your shim, for a total of .150 with your .090 shim?
SuperDave
- Aug 28, 2003
