cameron
How long are ye all getting from your belts.I put on about 1200 miles and went tru about 3.Also when they went the belts blew apart.Had to use a knife to them offf.Is this normal.My first belt i got 1600 miles.
thanks all
thanks all
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
I generally buy a new belt every season and run about 2500km. I change it out, not because of the belt failing, but just for better performance. Something definately aint right in your setup for such a short lifespan with your belts...to much heat in your clutching system.
There are many things you can look into:
Belt tension may be too tight.
Clutches may be out of alignment.
Clutch springs (helix position) may be too weak, causing poor belt grab.
The chain in the chaincase may be too tight.
Bearings on the jackshaft or driveshaft might be shot.
The track may be too tight causing too much tension/tightness in the drive system.
Idler wheel bearings may be shot.
You may be too fat/heavy
(like me) for the stock clutch settings.
There is some form of inefficiency in your clutching system, you just have to find where you can improve it. Look in your owner's manual (or do a search here) on these items and you may find your answer. It may very well be a combination of these things.
(like me) for the stock clutch settings.There is some form of inefficiency in your clutching system, you just have to find where you can improve it. Look in your owner's manual (or do a search here) on these items and you may find your answer. It may very well be a combination of these things.
cameron
thanks for the advice.i carryed it out to the dealer and they told me that the the bottom end of the cluch was burned up.Do many poeple out their have this problem
sinjin
I got over 3600 miles on my belt and it is still good. Will change it out this season and use the old one as a spare
- 8K
